Re: 2404 hydraulic pressure
Posted by mic h 560 on December 06, 2009 at 15:05:58 from (206.53.147.1):
In Reply to: 2404 hydraulic pressure posted by mic h 560 on December 05, 2009 at 22:53:43:
That was my first thought also so I took that apart and it apeared to be fine. Everything inside the valve looked very good no scars and fight really well. When the tractor is running and the 3 point is not topped out it has 0 hydraulic pressure. Maybe I am not understanding the system right.
