The hydraulic system is an "open center" type system. That means that the oil leaving the hydraulic pump goes through the various valves and then returns to the reservoir. As long as no valve is putting a demand on the system the oil just returns to the reservoir and you will have no pressure in the system. When a control valve is moved the oil is diverted through that valve to what ever is attached to it, a motor, cylinder, power steering, etc. The pressure will then rise to whatever is needed to move the cylinder or motor and no more. If a cylinder should reach the end of it's stroke so that it can move no farther, the pressure in the system will rise until the relief valve opens. At that point you will hear the squealing caused by the oil escaping past the valve. That will be the maximum pressure the system capable of delivering.
If your power steering works when the system is on high pressure, caused by the hitch system, but not working any other time, the steering system is working but not getting the priority flow it needs. The priority valve works on flow, not pressure. The steering system is also an open center system so when no load is placed on the steering there will be no pressure rise there. However, when demand is placed on the steering system, the pressure will rise, but only in the oil that is flowing from that side of the priority valve. The remaining flow to the hitch will still pass out of the valve with no rise in pressure.
What it sounds like is happening is that when you activate the steering the flow through that part of the system stops and all oil flows to the hitch. When the hitch valve causes the pressure to rise it is also rising in the steering system to allow it to work.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
