Posted by Owen Aaland on December 06, 2009 at 16:09:17 from (65.165.246.148):
In Reply to: 560 Clutch posted by Texas Denny on December 06, 2009 at 07:40:41:
The TA in my 460D slips on the low side. As long as the load is light the TA works Okay.
As the rollers wear in the TA assembly they get flat sided and grooves are worn in the ramps. When that happens the rollers no longer roll on the ramps to grab the carrier tighter as the load increases and they will begin to slip.
If the main clutch was the problem in this case, the slippage would be worse with the TA lever ahead, since in that position there would be more torque required of the clutch for the same load on the tractor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
