Re: Ring Gear Removal on H
Posted by Bob M on December 06, 2009 at 18:20:48 from (74.74.133.11):
In Reply to: Ring Gear Removal on H posted by BruceS. on December 06, 2009 at 07:56:01:
Bruce - NO WAY the flywheel can be removed without splitting the tractor. The clutch disc and pressure plate assembly yes - but not the flywheel!
How once the flywheel is off changing the ring gear is straightforward:
Remove the old gear by heating it gently with a torch. (Doesn't need to be terribly hot - 300 deg is enough). Then quickly tap around the ring gear with a hammer before it cools - it will work right off.
Installing a new gear is even easier. "Bake" the new gear in a 400 deg oven at for a half hour. The hot gear will now fit easily onto the flywheel and shrink firmly into place as it cools.
