Re: A has antefreese in oil
Posted by ScottyHOMEy on December 06, 2009 at 18:52:46 from (70.105.235.89):
In Reply to: Re: A has antefreese in oil posted by keaggyheg on December 06, 2009 at 18:00:33:
Did you get the bolts across the rear? You have to remove the half-moon cover at the front of the torque tube to get to them. If you got those out and she's still stuck, then it's time for a thin, stiff scraper to see if you can get find a weak spot to get through and then work your way around. Be patient and work your way around so that you don't distort the rim of the pan by pulling too hard on it before you have enough of the gasket loose.
