Re: re push rod
Posted by Lloyd Sorlien on December 06, 2009 at 21:05:53 from (209.62.233.88):
In Reply to: Re: re push rod posted by Seth Boyer on December 06, 2009 at 16:24:37:
yes I know the tappet was right on. the nut was not loose. I think the valve maybe got stuck in the valve guide amd let the push rod off the tappet. yes I know how to ajust the clearence.
