Re: F-12/F-14 conversion
Posted by ET on December 07, 2009 at 07:02:41 from (134.179.104.135):
In Reply to: F-12/F-14 conversion posted by Seth Boyer on December 06, 2009 at 12:30:04:
Does the serial number on the tag match the number on the engine? I would use the gas tank and maifold set up, I think there were less of them than distilate and it will be easier to deal with. I have a 37 F12 with the wide front and heisler overdrive, remember the pto and belt pulley speed up too so you may want to remove the pulley. Whats the deal on the front axel? It looks like a model A ford wheel on it.
