Re: Farmall M Rough Idling
Posted by Bob M on December 07, 2009 at 07:28:50 from (151.190.254.108):
In Reply to: Farmall M Rough Idling posted by Jim R on December 06, 2009 at 18:45:38:
In addition to Brownie's suggestions use a timing light to check operation of the centrifugal advance.
If it's working timing will advance from 0 deg at slow idle to about 35 deg BTC at governed RPM.
You won't need to change carb jets to run at 5,500 ft.
