Re: Flushing a radiator
Posted by rustyj14 on December 07, 2009 at 07:50:00 from (173.75.31.48):
In Reply to: Flushing a radiator posted by redFarmallboy on December 07, 2009 at 04:38:11:
The auto parts stores sell a product known as Radiator Flush. Buy a can and read the instructions, and see what that does. You might also do, or have a mechanic do, a compression check on the cylinders, to see if the rings, or valves, are in need of work. A leaking head gasket will give oil in the radiator, too.
If the oil in radiator persists, better seek professional help! It'll only get worse! Engines do not heal them-selves!
