Re: 1970 - 444 gas IHC - No Start
Posted by El Toro on December 07, 2009 at 17:28:28 from (74.103.74.58):
In Reply to: Re: 1970 - 444 gas IHC - No Start posted by rlm2139 on December 07, 2009 at 17:12:35:
Remove that hose and then hold your hand over the throat of the carb. Have someone else to try to start the engine. Have the ignition switch in the on postition. You don't need to use the choke as this should choke the engine. If you don't have much suction. I would do a compression test and write down the readings on each cylinder. Hal
