Posted by Owen Aaland on December 07, 2009 at 22:32:17 from (65.165.246.148):
In Reply to: Oil pan leak posted by railhead on December 07, 2009 at 20:56:42:
CSK said: (quoted from post at 00:56:42 12/08/09) Hi all,
I have a farmall m that was recently rebuilt and after I installed the oil pan it had a leak between the pan and the block at the left front corner. I later removed the pan, cleaned and reinstalled it. It still has an oil leak in the same spot. The pan does not appear to be bent and I used silicon and a cork gasket both times. I tightened the bolts starting in the center and working to the ends. I would like to paint the tractor this spring but obviously want to stop the leak first. Does anyone have any recommendations on gaskets, sealants or anything I may be doing wrong in installing? This is my first tractor project and I would appreciate any help.
Thanks,
Cory
Remove the pan and take a real good look from the inside at the area that leaks. Most likely you will find a crack. They can usually be successfully repaired by brazing.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
