350 Utility, C175
Posted by loafersglory on December 08, 2009 at 02:59:04 from (72.71.207.83):
C175 rebuild. Have main bearing bolts oiled and torqued to specs. The bolts have a thick flat washer under the head. They also have a wire hole in head. How is this wire hole used? These bolts came with replacement block so I did not see how they were originaly. Should I use thread sealer on bolts or is this unnecessary? Thanks, LG
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
