Re: Gin pole on a Super A ?
Posted by mkirsch on December 08, 2009 at 05:26:43 from (64.80.108.57):
In Reply to: Gin pole on a Super A ? posted by Dalex on December 07, 2009 at 10:37:54:
I am pretty sure the rated capacity of the fast hitch will do 500lbs right at the end of the socket, but capacity is reduced the further away from the end of the socket you go.
You probably don't have the helper spring, right? Unless someone put a rockshaft off a 100, 130 or 140 on there when they retrofit the fast hitch, a helper spring won't fit. The later rockshafts have a place to attach the helper spring.
