Posted by ScottyHOMEy on December 08, 2009 at 11:53:35 from (71.241.196.24):
In Reply to: Re: Headlight bulbs posted by plow hand on December 08, 2009 at 11:43:32:
We're kind of shooting in the dark here. If they are the teardrop style, with one wire going to each light, the bulb numbers are in my post above.
If, however, you have the sealed beams (a much flatter appearance than the teardrops, and the bulb is also the lens) then it's a whole different story. There are two wires to each and, as in the teardrop style, there are two different bulbs (6v and 12v).
In either case, they are a single filament bulb. Bright is obtained by allowing the full system voltage to flow to the bulb. Dim is accomplished by switching a resistor (part of the switch assembly) into the circuit. The dimming resistor only affects the headlights. The rear light gets full voltage any time it is switched on.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
