Re: MD diesel charge pressure
Posted by M Diesel on December 08, 2009 at 15:06:34 from (12.24.61.12):
In Reply to: MD diesel charge pressure posted by tackhammertime on December 07, 2009 at 13:09:48:
35 to 40 for the main oil pump maybe, but unless I'm reading it wrong the "lift" pump (primary pump in IH lingo) is 58 to 65 per book spec (PU27). I'd like to see a copy of that manual page? They will operate reasonably down to the 35 level and many seem to be at that pressure these days. FYI, main oil pressure is 38 to 46 psi for the diesels.
