Re: Converting to live hydraulics
Posted by deano4863 on December 08, 2009 at 16:37:37 from (76.30.75.21):
In Reply to: Converting to live hydraulics posted by deano4863 on December 08, 2009 at 12:45:22:
Ok that helps. Next question. The suction side is 1" and the block then reduces to 3/4" going into the pump. Using the belly pump as a reservoir only allows a 1/2" on the bottom as a suction port. Is that going to work? Hydraulics will primarily be used for a dual cylinder 3 point hitch and as a remote to adjust cutting height on a shredder.
