I am in the process of putting live hydraulics on my 1940 Farmall H. It does not have a belly pump. It is a "distillate" model, so I built a tank to hold the hydraulic fluid and mounted it where the distillate tank was mounted. I had to change the 1/8 inch plate on the front of the block and also the cover plate to get the bolt pattern correct for the pump. I don't think you need a threaded fitting on the suction side of the pump. I plan to just use hose clamps on mine. It is gravity fed as I understand it. The tank got painted today and will be installed in the morning. Tomorrow I will get the hoses I need and hook it up. I would give you a picture if I knew how? If you want to email me, I can email you pictures.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
