Re: Farmall A with Siphon cooling system
Posted by gene bender on December 09, 2009 at 02:54:59 from (67.55.226.179):
In Reply to: Farmall A with Siphon cooling system posted by ihalltheway on December 08, 2009 at 11:39:18:
I just take the pan off and then with a good lite you can look at all the sleeves and you will probably see the green color at the bottom of which sleeve it is leaking. Not that hard to pull the sleeves and install new o-rings. You will probably find the cavity around the sleeve built ip with lots of sludge that needs to be removed anyway for better colling. You could also add a waterpunp then try sealer and with the pump just mite fix the leak. The tractor is worth fixing.
