Re: cracked super M block
Posted by kossuth on December 09, 2009 at 09:40:42 from (214.3.220.14):
In Reply to: cracked super M block posted by WOpp on December 09, 2009 at 07:38:24:
Jim Stuart said: (quoted from post at 08:38:24 12/09/09) Just bought a super M with a 3" horizontal external crack in the block behind the carbuerator. Can this be welded without tearing down the motor? Looks like it has J&B Weld on it now and is seeping some fluid. Can applications like J&B weld hold for long? It looks like this has been on the tractor for a long time.
Depending on the crack I'd be half tempted to leave it alone. If it is in a nonpressurized area of the cooling/oiling system and all it's doing is just weeping alittle oil just check your oil every so often and run it. A pressurized leak is another matter though. My dad's M has a crack in the block running horizontal on the motor on the opposite side you mention and it's been that way for 40 years. Hasn't hurt it yet.
