Re: Hand start on Farmall H
Posted by glennster on December 09, 2009 at 13:45:04 from (76.217.101.141):
In Reply to: Hand start on Farmall H posted by narrowfarm on December 09, 2009 at 13:38:49:
if the tractor still has the mud shield on the bottom of the bolster, remove it and see if the starter crank unit is packed with field dirt. you may need to dig all that out, then use compressed air to blow all the debris out. then give it a real good soaking with your favorite penetrating oil, keep working the crank in and out , it will eventually clean up.
