Re: MD diesel charge pressure
Posted by M Diesel on December 09, 2009 at 15:31:08 from (12.24.61.12):
In Reply to: MD diesel charge pressure posted by The tractor vet on December 07, 2009 at 13:09:48:
Yup, pretty familiar with the things. I have more than one pump than runs on the shy side of 40 lb is why I ask. It doesn't match the books, but they run okay. I kinda thought it was spring fatigue reducing the pressure but it seems odd that the output pressure is that low when I have others just as old that run at the high pressure. IH not numbering their gauges doesn't help to clear up the issue.
