Posted by sdfarmall #2 on December 09, 2009 at 17:31:52 from (208.53.229.30):
In Reply to: ih 706 wont start posted by oslodan on December 09, 2009 at 17:09:56:
On the rear of the Carb there is a soloneid that when the power is cut to it, it plugs the main jet in the Carb. When you turn the key it retracts and allows fuel to flow. (It is suppose to keep the tractor from decelling when you shut it off) The way I checked mine was to shut off fuel, take the solenoid off, ensure the wire is plugged into it and then turn the key on. Once you turn the key on go back and ground the solenoid and it should retract. If it doesn't it could be your problem, if not you know its good. Good Luck
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
