Re: 100 govenor
Posted by Bob on December 09, 2009 at 17:43:19 from (69.178.228.68):
In Reply to: Re: 100 govenor posted by Bob on December 09, 2009 at 17:25:16:
To add to that, the action of the governor is trying to force the shaft rearwards.
Also, the timing and governor gears are helical and the governor gear will tend to be forced one way or the other, depending on the slope of it's helical gear, which I don't know offhand, with a force depending upon the load the gears are under.
I would GUESS that force is towards the rear, as well.
