Re: What are differances of IH 504 Utility+504 Farmall
Posted by Bernie Steffen on December 09, 2009 at 17:53:47 from (173.31.110.88):
In Reply to: What are differances of IH 504 Utility+504 Farmall posted by narrowfarm on December 09, 2009 at 09:53:03:
Buddy of mine hs a c153 engine in a C Farmall. He said if the engine came from a combine or whatever, used as a auxilary engine, it would not have sleeves. If it came in a tractor, it would have sleeves. Aux engines are also not drilled for pilot bearing. 153 engine is much different than 123 or 113. 153 has water pump in a different place. Just a little info as I have been told. Bernie Steffen
