Re: farmall cub problem running
Posted by rusty wheel on December 09, 2009 at 17:56:53 from (75.180.27.253):
In Reply to: farmall cub problem running posted by farmall cub dave on December 09, 2009 at 17:43:33:
It probably is sucking air from somewhere, around the butterfly shaft or the gasket. Think about what you're doing when you close the choke. You're reducing the amount of air. squirt some oil aroud the gasket and the shaft and open the choke a little and see if it runs better. That may tell you where it's getting the air.
