continous use of H lift all pump
Posted by Curt from MN on December 09, 2009 at 20:24:20 from (72.2.207.20):
I wired the lift all pump lever back so that it is always on unless the the clutch is disengaged or the motor is off. Is there any severe wear to the pump from doing this or will it be OK as long as fluid is moving through the system? I did install an open center spool for use with 2 way cylinders for the loader.
