If you have enought stuff for tools and odds and ends, you can make one yourself. Hal's pic below of Keith's gives you the concept -- basically a brace at the top, a piece on the bottom to draw upwards, and a threaded section between that is used to draw the bottom up against the bracing on top.
I've made one using a couple of scraps of steel bar on top, set just wide enough so that the upper lip of teh sleeve has clearance to come up between them. Bridged that with the center section of a two-jaw puller. All thread down through that and the sleeve. On the bottom I used the center section of another puller, but I wasn't worried about saving the sleeves.
On the one pictured, the piece at the bottom is what some call a puck. It's basically a disc, with the upper edge turned on a lathe to fit the inside of the sleeve, and the wider bottom forming a lip to pull on the bottom edge of teh sleeve. In theory, if it's set up straight, it reduces the possibilty of distorting the sleeve in the process of pulling it.
If you're not aiming to reuse the sleeves, I'd try driving them out first with the wood block and a deadblow hammer. If that doesn't budge them, then rig a puller. Even with the puller, it may be necessary to soak the upper lip of the sleeves with your favorite rust-buster/penetrant and, for especially stubborn sleeves, maybe even apply a little judicious heat to the surface of the head surrounding the lip.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
