Re: farmall cub problem running
Posted by El Toro on December 10, 2009 at 07:07:40 from (74.103.74.58):
In Reply to: farmall cub problem running posted by farmall cub dave on December 09, 2009 at 17:43:33:
You need to make sure you're getting a good flow of gas to the carburetor. Remove the gas line and see if there's a full stream of gas. If you have inline filter I would remove it. If the gas flow looks ok remove the tube fitting where your gas line connects and see if there's a screen behind the fitting that may be clogged. Hal
