Re: Coil question
Posted by JMOR on December 10, 2009 at 07:13:46 from (72.181.166.239):
In Reply to: Coil question posted by gene bender on December 09, 2009 at 12:24:54:
danto said: (quoted from post at 21:48:21 12/09/09) Thank you, it reads 1.5 ohms, so it is a 6 volt coil. Now that brings up another question - is there a way to be sure that I have a 6 volt regulator, anyway to test that? Thanks again.
Yes, you can measure it. Need a variable voltage DC power supply. Connect ARM & GND to supply & slowly increase voltage until cut out pulls in (a bit above 6 or abit above 12) and similarily for regulator contacts (~7.7 or 14.4) and looking for those contacts to open rather than close as cut out does.
This post was edited by JMOR at 07:14:52 12/10/09.
