Re: Cub engine rolls up and down
Posted by ScottyHOMEy on December 10, 2009 at 07:31:12 from (70.105.226.207):
In Reply to: Re: Cub engine rolls up and down posted by Nicholas Whitman on December 10, 2009 at 07:22:07:
In that case, I'd make sure the carb itself is good and clean and the float and needle in good shape and adjusted, and then make sure, as old suggested, that you aren't just set too lean. From there, if that doesn't get it, I'd start looking at the governor. If the problem strikes you as radical, or if it can't be adjusted out with the bumper spring screw, then it's probably time to open it up and have a look at the main spring and everything else.
