Pulled the carb drain plug - good flow there. Cleaned the bowl and inline screens. Found some small particles of red paint/rust, but not enough to impead flow. Dissassembled carb - no dirt evident. Float and valves are good - replaced a couple of years ago. Blew carb cleaner through passages and reassembled. Set the mixture screw at two turns out - usually set to 1.5 - so a bit richer as suggested.
I have never adjusted the governor. Took a look and found the bumper spring screw was socked down all the way - no thread showing. Removed the whole threaded assembly. It look good, spring and ball on end seemed ok. Reinstalled with about 1/4 inch thread showing.
Tractor started right up. Gave her a run pushing back the snow banks. Ran without "rolling" once.
Can't exactly say what fixed it but we're operational.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
