Re: super a block
Posted by El Toro on December 10, 2009 at 13:51:07 from (74.103.74.58):
In Reply to: Re: super a block posted by zack m on December 10, 2009 at 12:50:08:
Other blocks may work, but you need to be careful
since your tractor has hydraulics. I think your sleeves are thicker since your 123cid block has the block number 354898R1. The C113 blocks
used on the early Super A's had sleeves that were 6 7/8" long and the diameter of the sleeve
at the seal end measured 3 5/16". If you look under tractor parts to the left of your screen under Marketplace the 140 uses sleeves that are 6 7/8" long and are 3 5/16" in diameter. Once you get a piston out you can measure one of your sleeves. You will need to pull the sleeve I think to measure the diameter. There may not be enough protruding through the seal to measure. Hal
PS: Those engines are easy to work on. Just take a few pictures during the tear down and separate all your parts into cardboard boxes and mark them where they were removed so you don't spend a lot of time looking for the part during reassembly.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
