Re: SC rear main and rear axle seals
Posted by ScottyHOMEy on December 10, 2009 at 15:09:45 from (71.241.220.190):
In Reply to: SC rear main and rear axle seals posted by Mark on December 10, 2009 at 14:26:43:
As far as getting you fan off . . . The nut on the back end should hold in the slot on the back of the casting. To break it loose, look just forward of the casting and you should see a hex surface (looks like a nut) that is actually part of the spindle. You need to get a wrench on to that to loosen it. It's a narrow gap behind the pulley to get to it, so it may take a tppet wrench. If you get lucky, it will be 7/8". Unlucky, it'll be a 13/16".
But that's the party you turn to get it started. As you losen it and the nut on the back end of the outlet bracket is more accessible, turn whichever is handiest.
