Re: super a block
Posted by CNKS on December 10, 2009 at 18:09:31 from (216.144.104.128):
In Reply to: super a block posted by zack m on December 10, 2009 at 07:25:27:
That is a Super A block 354698. FAAM is the serial prefix for a Super A engine. 140, or at least the 130 engine prefix is C123. The 3 inch sleeves indicate that it is for chassis serial 350xxx-up, preceding the Super A1 (same block)The outside sleeve diameter at the o-ring is 3 7/16 or 3.4375 inches. The 3 inch diameter sleeves indicate that it really is a C113, the same block was in the C123 Super A1 and Super C. If you overhaul it, it will use 3.25 inch sleeves. My identical SA engine is in the machine shop waiting for the crank to be ground, etc.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
