Posted by J.J. from Afton on December 10, 2009 at 22:04:51 from (24.118.175.64):
In Reply to: F-20 Block & Sleeves posted by doehmke on December 10, 2009 at 21:41:46:
Ya Id say if you are pulling one you might as well pull the rest and replace the o-rings now rather than hfinding out they are bad later. Of course be sure to clean all the grooves really well. You may also want to wire brush/clean up the outside surface of the sleeves before re-installing them. If you plan to hone the sleeves at all you may want to do that while they are removed, just to make the cleaning afterward easier.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
