Posted by Brownie 450 on December 11, 2009 at 08:59:01 from (66.43.241.141):
In Reply to: Battery Tenders posted by Dellbertt on December 11, 2009 at 05:39:11:
The tenders & "automatic" chargers that I've repaired have circuit boards that aren't made in the USofA. Silicon controlled rectifiers which control the charging cycle are usually of marginal capacity & are pop-riveted to a heatsink that was made from a sardine can. There is usually less than $5 worth of components in the control board. The transformer is also of marginal capacity. I usually put a 3-5 amp charger on my "off season" batteries every 3-4 weeks for an hour's charge. Works well for my situation.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
