H's start good when cold, if it turns over good, winter grade gasoline, and engine oil like 10 w or 5w30 and engine in good tune and reasonably good shape. If you have a 6 volt battery in the original size battery box it can be difficult to find a battery that size with really good cranking cold cranking power and or ampere hour ratings. Like others have said, good heavy cables, starter in good shape, I will add on starter to make sure it has a center bearing as some did not and under heavy cold starting torque situations it can cause armature drag. And it does help some to turn on the lights for a little while to help surface of plates on battery to warm a bit. Slow charge for a while before trying works good also. Many variables. During cranking the voltage will drop to about 5 volts or less so coil will naturally produce a weaker spark than at normal operating voltage of about 7.2 volts. Low voltage causes less current to flow through the primary winding in coil there for producing a weaker magnetic field in the secondary coil winding and you end up with a weaker spark .
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
