Posted by loafersglory on December 11, 2009 at 16:03:20 from (72.71.207.217):
In Reply to: F-20 Block & Sleeves posted by doehmke on December 10, 2009 at 21:41:46:
Sounds like you’re off to good start. I have a 1958 IH 350 Utility that threw a connecting rod through the block. After getting a used block I am slowly piecing it back together. I did invest in an engine kit, had the crank ground and a valve job done. Other than the oil pump everything else seems serviceable. Like you the thrill of finally starting it up will outweigh the busted knuckles and grease stains. Good luck. AR
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
