Re: Super A is very cold and cannot be towed.
Posted by Haas on December 11, 2009 at 17:39:46 from (70.220.227.64):
In Reply to: Re: Super A is very cold and cannot be towed. posted by gene bender on December 11, 2009 at 16:03:24:
There is plenty of transmission vent on all the letter series tractors. The gear shift levers are not sealed off for one. I'm not sure if the A final drives have a way to vent or not. However, if there is a seed plate drive on them, then they can vent through that. If you run your M several times a week and actually use it, you will likely never have a condensation problem in the transmission, as it will get warm enough to drive out the moisture.
