Nicholas, look closely at where the cross shaft (rod going across front of engine and into governor) goes into the fitting on the governor. It is common for it to develop play there from wear on the shaft and woodruff key. Only very slight play can cause a lot of surging, delayed response, etc. easy solution is to remove the rod and put some loctite on it and reinstall, unless it is so loose it needs a bushing. coke can is good for making bushing out of.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
