Re: Super A axle seal, please help
Posted by Haas on December 12, 2009 at 07:29:41 from (75.202.225.57):
In Reply to: Super A axle seal, please help posted by RJV on December 11, 2009 at 19:46:55:
I think you are talking about the pinion shaft at the top of the final drive housing. To remove this shaft, you have to remove the final drive assembly from the tractor. I think the bearing would come out after the small cover over the end of the shaft is off, but there is no way to get hold of the bearing to remove it. That would do no good as far as fixing the seal problem. To do that, you must remove the final drive from the tractor, then remove the brake drum from the shaft. The brake drum is held in place with a set screw and a woodruff key. Sometimes the drums are tight on there and hard to get off. You have to rig a puller to get the drum off. Don't try to drive the shaft out, as the woodruff key will prevent the shaft from going through the bearing. Once the drum, and key are off, the shaft with the bearing will come out through the hole that has the cover with 4 bolts. While you have this off, you should also replace the seal on the transmission side as well and you may want to put new brake bands if the old ones are worn and/or oil soaked. Be careful when removing the final drives. Do one side of the tractor at a time and make sure everything is blocked up securely. These tractors can be unstable due to the offset design. When the wheels and final drives are removed, they can easily tip over if not properly cribbed up.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
