Re: Plow and Tire size questions
Posted by Armand Tatro on December 12, 2009 at 17:12:52 from (71.201.22.21):
In Reply to: Plow and Tire size questions posted by Cub n M in Or on December 12, 2009 at 13:39:19:
If you decide to reduce that plow DO NOT CUT THE FRAME IF AT ALL POSSIBLE in case you get a bigger tractor and want to put the bottom back on the plow. That tractor might be able to pull a 3Pt. 4 bottom because a mounted plow pulls easier than a trailor plow. Try it as a 4 bottom first. With only 10 acres to plow it would not be that big to plow in first gear and would be less hassel than taking a bottom off and you would still have a factory original plow. Armand
