Farmall H Wont Stay Running
Posted by Tweeter on December 12, 2009 at 19:32:02 from (72.9.30.38):
I have a H that will not run longer than a few seconds. I took the carb apart to replace the float. Put new gaskets in carb while off. Since then it will not run long at all. Removed the drain plug a bottom of carb and does get a steady flow for lengthy amount of time. It also had an inline filter for the fuel which I removed and put a fuel bowl on instead. What could be the problem?
