Re: Farmall M Ignition Wiring
Posted by soybeanjoe on December 13, 2009 at 08:37:50 from (66.213.171.108):
In Reply to: Farmall M Ignition Wiring posted by 2510Paul on December 13, 2009 at 07:23:05:
As others have said, the resistor is either the wrong one or has gone bad. I have seen brand new ones that came out of the box bad.
My recomendation would be to remove the points & condensor & put in an electronic ignition system. Then you won't need a resistor or worry about replacing points or fouling plugs as much and my experience is that the tractor will runbetter.
I have a SMTA that was continually fouling plugs until I put in an electronic ignition. Since then it hasn't fouled a plug. Also have a Toyota forktruck that would burn up a set of points in just a few days, was always fouling plugs, and was next to impossible to start without staring fluid even when kept in the heated shop. Put in an electronic ignition & haven't changed plugs since (3 years ago) and it started the other day sitting in the unheated tool shed without starting fluid at 8º
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
