Re: Plow and Tire size questions
Posted by Ferd on December 13, 2009 at 11:54:14 from (71.111.84.110):
In Reply to: Plow and Tire size questions posted by Cub n M in Or on December 12, 2009 at 13:39:19:
Had a friend that had a JD spinner plow only 3-14s. We were plowing some really hard ground up a fairly steep hill and he was using a JD 730D. He couldn't get enough traction to pull it uphill - only down but when he tried to drive uphill with the plow up, the front of the tractor would come off the ground and he had to back up. Those plows are heavy.
Here, 3-14's would be a pretty good load for an M in ideal conditions, but out soil is really hard pulling.
