Re: Hyd pressure Check
Posted by Wardner on December 13, 2009 at 15:04:18 from (4.154.247.227):
In Reply to: Hyd pressure Check posted by RDJ Farms on December 13, 2009 at 10:35:38:
[quote="RDJ Farms"](quoted from post at 04:39:59 12/14/09) Thanks for all the help. When using the block on ebay what type of auxiliary controll valve is used? quote]
Email the eBay seller. He will tell you whether open or closed center. You can then decide whether you want single or double acting.
I'll bet he has a website with good imstallation instructions. If not, they will probably come with the adaptor.
I bought a similar Cub adaptor from IH at least 30 years ago to run a dump trailer when digging out the barn cellar. They work fine but I can't remember the installation details. At any rate, you can buy the adaptor with confidence. You won't be disappointed.
