Re: Low compression on H
Posted by Janicholson on December 13, 2009 at 16:43:14 from (64.61.211.151):
In Reply to: Low compression on H posted by Alvin Dick on December 13, 2009 at 15:47:07:
First make sure (if it runs) that it is operated for at least 5 hours in a variety of loads, then check it again.
Second make sure the gauge is reading correctly and that it is sealed into the cylinder when checking.
Third make sure all plugs are out, and the throttle is wide open when checking.
Make sure it turns over briskly when cranking during the check.
Third put a table spoon of engine oil in each cylinder (if it is still low and then do the check. Let us know what you find. If all cylinders are as low as 25 the gauge is suspect, OR the cam timing is way off and then it would not run. JimN
