Re: Farmall Rims
Posted by CNKS on December 13, 2009 at 17:05:47 from (216.144.104.128):
In Reply to: Farmall Rims posted by gary sedlacek on December 13, 2009 at 14:34:06:
If it is an H, a 12.4 is ok, 13.6 on that size tractor is overkill. If it is an M, it likely has 11 inch rims, 13.6 will be fine, the 11.2 will not transfer all the HP the M has to the ground.
