Re: 300 r/c steering
Posted by Janicholson on December 13, 2009 at 17:26:51 from (64.61.211.151):
In Reply to: 300 r/c steering posted by BJHinIowa on December 13, 2009 at 15:09:14:
Best and easiest is to use a stock setup from either a 300F or 350F then all the pipe and valving will be perfect.
Many should be available in a salvage yard.
The term pump might be incorrect in your post. The steering is powered by the live pump and a priority/diverter valve. The device in the steering column is a torque motor.
Hydrostatic PS does have a manual pump in the steering column to make it turn, but there is no mechanical shaft to the front, and it was not used on 300/350 that I know of. JimN
