Re: 5088 ih
Posted by allen in nc on December 13, 2009 at 17:40:10 from (71.54.159.144):
In Reply to: 5088 ih posted by allen in nc on December 13, 2009 at 16:26:35:
man also stated that sometimes tractor would not pull off and clutch would have to mashed again and light would go off and tractor will pull,6500hrs
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
